installing the cam in the 4.8 is there any special procedure ive never installed a roller cam? and will the stock lifters work?
your stock lifters will work,
heres a how too
LS1Howto.com
its for a f body but 90% of it will work the same way ;)
good luck and hope it all works out well for ya, just make sure when you install it you be extremely carefull not to ding the lobes, and make sure you double check the marks when installing the timing chain
ive done like 3 cam swapa already on my 4.8,,really easy,,nuthin to it.get u some 5/16 rods to hold up the lifters before u pull the cam out..and get a torque wrench:)
