downed compression on cyl. 3!
guys i have lost just about all compression on cylinder 3 only. we you scan it it comes up as a miss fire on the computer. when we did the compression test it showed up as 25 psi not the usual 150 like it should be. the plug is fine but with alot of gas on it and seems to look like maybe the exhaust valve? the plug wires are fine injector pulse is good and no exhaust leaks. what could be cutting down on my compression and causing my problem? its putting my trans in limp mode and runs like dog crap!! check engine light is flashing and traction control is going nuts!!! need your help cuzz she is out of commission till i get help??????????????????????????????/:hyper2::hyper2::hyper2::ugh2::ma:
