Hey guys, which -heads and cam- do you think would be better for the 5.3L with the radix?
-Stock heads ported
-Get 6.0L heads
-Get LS1 5.7L heads
-01' Z06 cam
-02'+ Z06 cam
-212/218 comp cam
In advance, thanks for the help.
-Stock heads ported
-Get 6.0L heads
-Get LS1 5.7L heads
-01' Z06 cam
-02'+ Z06 cam
-212/218 comp cam
STOLEN: 2005 SILVERADO 1500 4WD ECSB 5.3L 3.42 gears
Sold: 2003 SILVERADO 1500 RC STEPSIDE 5.3L 3.73 gears
IMO with forced induction headwork is not that helpful. A cam might wake it up a bit, does Radix recomend a cam?
How about a set of 6L heads, that are cleaned up a bit (i agree with gmc, worked heads aren't needed) , bigger valves, and crank that boost up a lot. More boost will make more power than a set of heads will.
With a z06 cam, you are going to loose a lot of low end torque, the vette cam likes high rpm, will your charger keep making power up to 6500rpms?
I say the build the engine up as strong as possible, then boost the hell out of it. (the 6L heads will allow more boost), that should get you going.
Also, you might as well throw a 75shot NOS on it. hehehehe.
see ya,
allen
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
btw, post those 1/4 mile numbers and i'll update the truck list.
Nelson Performance
NP on Facebook
Youtube Channel
I forgot about lowering the compression good point Farmtruc, find a cam with low in torque for a forced induction.
hmmm maybe a low lift, 212/218 cam and 6.0L cleaned up heads......outta the choices
485rwhp/440rwtq SAE
Thanks for the quick answers guys.
I need to do a deep research on cams and also thinking of a smaller pulley for the charger and a stall converter.
Once the moddifications start is addictive, somebody stop me please![]()
NO!Originally posted by The_Mexican@Sep 25 2003, 01:48 AM
485rwhp/440rwtq SAE
I am with Sleeper no Now you have the bug. Max out credit cards, drain bank account, get a loan to mod. You are on your way.
1999 Silverado 1500 Ext. cab Red 2/4 hotchkis drop & swaybars, bilstein stocks, AR626 & 404 Nitto's, Yank converter, ASM headers, ASP underdrive pulley, Taylor wires , free mods VCN 2000, Nelson Performance tuning
2002 Red WS6 M6; Flow master K&N
You guys are mean, let him find out the hard way like I did!!![]()
