Anyone know what the Compression Ratio would be for an LQ4 with 243 Heads?
64cc chambers will bump you up to about 10:1 on an LQ4.
________________________
2006 2500HD, RCLB, 4X4
6.0, 4L80e, 14 bolt
LQ4 with 243 is 10.5
LQ9 with 243 is 10.9
I think thats too high. Show me your inputs into a compression ratio calculater that get you there. I went round and round on this when I was milling my heads because if you search the forums you will get wide ranging answers. Below is my attempt to quantify it for myself. Unless I am doing something wrong, I think you need 60 cc chambers to get to 10.5:1 assuming a stock head gasket.
http://www.ls1truck.com/forums/mecha...ion-ratio.html
6.0, 4L80e, 14 bolt
this has been the CR rule for years
a ls1 is 10.1 with 67 cc heads you toss on Ls6 heads and it becomes 10.5 which is the stock LS6 motor CR
just like a ls1 with 61 cc heads [5.3 heads] becomes 11.1
LQ9 and LS2 are same motors minus the heads.. a 72 cc vs 64.5 toss 64.5 on a LQ9 and you get same SCR as LS2
just like a 4.8/5.3 with 243 is 9.1
sme as 4.8/5.3 with 241 is 8.8
same as 4.8/5.3 with 317 is 8.4
i used to know the formula off top of my head. these numbers been proven over and over and over again.
I hear you and what you are saying makes some sense, but there are a lot of folks that would disagree with you on other forums. Rick@synergy on pt.net as an example. Dont know him personally but he makes his living doing this so I have to give him some credibility. His numbers are almost spot on with mine.
Im not a machinist so I cant say for sure. But I think the approach I used with the compression calculater is reasonable and I am sticking with my number until someone proves me otherwise. Like I said, I had a heck of time researching this because there is conflicting information out the wazoo.
6.0, 4L80e, 14 bolt
here just cause a person is of buisness doesnt mean they know what they are doing. Any person can have a buisness. not knocking anyone speaking in general
here is a calculator
Engine Size and Compression Calculator
i stand corrected its 10.4 not 10.5
the drop from 72 to 64.5 cc in head is a gain of almost .9
