I bought the 3 wire ECT (88988301) but all 3 wires are the same color and it did not come with a diagram. Which wires go to the ECM (1 yellow and 1 gray on my 6.0L engine harness) and which wire goes to my temp gauge (green wire for my 93 Yukon)??
1993 GMC Yukon 2dr 4x4, 6.0L/4L80E swap, Wheatley Tune, 3 inch Magnaflow true duals, 6.5 inch Dick Cepek stage 1 lift, 35's, 4.56 gears, front Posi-Lok.
I think it is the one opposite the lock. You could test it with a multimeter. It should be the only one with resistance to the outside of the sensor.
Well my OHM meter might be broken, but I'm not getting any resistance from any pins on the sensor. Is there any other way to tell what pins go to what wires?
Get a new multi meter that the OHM function works on...you should get 0 resistance between them when you have the right wire to pin relationship....i think
2000 PSD F250 Super Duty Ext cab long bed 4x4 - a few mods...450+ HP 500+ lbs of torque!! (Daily Driver)
1993 YJ "Buggy"
1991 3/4 ton Suburban 6.2L turbodiesel
i think this is what your looking for....
A = black............coolant temp input to ecm, low reference
b = yellow...........coolant temp input to ecm, sensor signal
c = green............coolant temp input for cluster mounted temp gauge
<div class='quotetop'>QUOTE(hummertech @ Oct 13 2006, 09:10 PM) [snapback]69350[/snapback]</div>i think this is what your looking for....
A = black(gray 6.0)............coolant temp input to ecm, low reference
I'm putting a 2004 6.0 from a 2500 in a '67 PU and my temp sensor in the head has only 2 pins (and the connector has only 2, black and yellow). Wiring harness from Speartech.
Do I need to get a 3 pin sensor in order to have output for a temp gauge? Or does the gauge input come from somewhere else on this motor?
I plan to use aftermarket gauges when I get to the dash. Do you have a PN for the three pin sensor?
<div class='quotetop'>QUOTE(Bill Ford @ Oct 16 2006, 06:33 AM) [snapback]69653[/snapback]</div>put the aftermarket sensor in the right side head or the radiator, its not as accurate in the radiator but it still works. www.hotrodlane.cc sells a adapter for installing aftermarket gague senders into the 6.0 right side head, some kind of metric o-ring fitting...that works good.I'm putting a 2004 6.0 from a 2500 in a '67 PU and my temp sensor in the head has only 2 pins (and the connector has only 2, black and yellow). Wiring harness from Speartech.
Hummertech: thanks, that diagram was exactly what I was looking for!
Bill Ford: 3 wire ECT sensor PN 12551708 and connector PN 12102748.
[/quote]
John Spear tells me that I should use the sender that comes with the Gauge Set I choose in order to get the resistance values correct for the gauge. So I think the adapter route in the passenger side head would be the best way to go.
However the 3 wire ECT Sensor would be the easiest way. Does anybody know what the output of the 3 wire sensor is? Perhaps the output is the same for all gauges?
Sorry to bring back an old thread but I just wanted to post that the plug for the TBI throttle position sensor is the same as the three wire coolant sensor. I'm sure the info should be useful to someone sine the connector cost 55.00 from a stealership. If you don't have your old TBI harness around you can order TPS plug from summit, 6 bucks I think.
