Results 1 to 2 of 2
Thread: 5.3l swap into obs transfer case
    Dec 2014
    '01 5.3l with tranny and transfercase dropped into a 99 tahoe
    Hvae a painless wiring harness - most of it is installed now
    Have the computer flashed already
    My next question is the new harness hass no connections going to the transfer case. so im assuming that i will be using the original wires from the old harness because the switches for it are in the cab and dont go through the new computer,,, is this correct?
    Dec 2014
    my other question is for the fuel pump wire .. i am running the original fuel pump since i read it should do fine with the stock motor. the only thing ineeded to do is change the control wire from the old computer to the new one.. there is a wire provided for it in the new harness i just want to make sure im cutting the right wire.
    on this diagram i thought i was supposed to take off the Drk Grn/Wht wire that says fuel pump but now im 2nd guessing myself ... any help on this
    this wiring diagram is for a 99 tahoe btw
