87 chevy k10 lq4 swap
ok im new to this swap stuff ive done alot of homework on it but im close to d day with the truck and a little nervous so here the scoop 87 chevy it is my baby been in this truck since i was 12 my uncle owned it first then my dad then me and it had a tbi 350 and its seen some miles mud and off roading from me i blew the engine last month i new it was tired and bought a lq4 the begining of the year it has a 700r4 in it that was rebuilt last november i had it built to 500hp cause i new i was putting the lq4 in it i already have dirty dingo engine mounts,adapter for tranny,computer has been sent out now my question is fuel related what pump do i need a new fuel selector valve
old engine
any wiring diagrams on these trucks would be nice any info would also be appreciated gentlmen help a kid out also keeping the return line
Progress engines pics will be up soon headers are on the pain in the ass
I am doing this swap in my CUCV. Hurry up so I can see all the problems you have. Is your motor 99-02?
hey man, i am really interested in your thread! i've got an 02 lq4 going into a 1980 k5. same engine, same body style. same problems!
here's my thread.
http://coloradok5.com/forums/showthread.php?t=298232
i am figuring out the solution to the same problem at the same time, so this is all of MY research: (it may not be right, my engine isn't runnin yet!!)
for fuel, your 87 tbi tank should already have baffles. ( i am gunna buy a fuel tank for a 1991 k5)
EP-241 and EP-381 AC/DELCO pumps will fit in an 87-91 fuel injected Squarebody sending unit, and they put out the proper pressures for an LS. (58 psi)
the 02 lq4 fuel injection rail has a regular already built in, AND a return line, so you don't need the corvette regulator.... all you need is a straight fuel filter.
http://www.speedwaymotors.com/Hi-Pre...ter,46386.html
our fuel should go
tank----->>fuel filter---->>> fuel injection rail -------->> return line ----->>> tank
drew
Thanks man but I figured mine out my truck came with fuel injection so my filter in the truck is fine the shoenfield headers didnt work they didn't clear my shift linkage so I got stock Doug thorley make headers for this swap call them they don't have them on the site yet also I put walbro 255 in each tank so I'm good there it has baffles thanks man should of went to the 700r4 less electronix my opinion tho thanks for the help and ur service there sir
How hard was it getting the engine in the truck and mated to your 700R? Want to put my motor in this week.
- You may not post replies
- You may not edit your posts
