Page 1 of 18 1 2 3 11 ... LastLast
Results 1 to 10 of 178
Thread: 94 Lifted Silverado 6.0/4L80e swap Build
    Jun 2009
    Caledonia, MI
    Hello guys, I am finally doing my swap that I've been talking about doing for the past 2 years LOL. First off I am working with a 1994 Silverado Z71 1500 4x4. I plan on putting a 6 liter in it along with a 4l80e and swapping input shafts for me to keep my old transfer case. So far right now, I just got out my old motor, and still have to pull the tranny. But at;east I am getting there slowly. A little more about the truck...It USED to have a fresh 5.7 350 crate motor with a comp cam and performer intake with edelbrock headers, tbichips stage 3 and some other goodies. The truck has a 10" lift on it with 4.56 gears and a 14 bolt full floater with Detroit Locker. Heres a video of the old setup....http://www.youtube.com/watch?v=BqoZLWVpuFo. But for the swap this is what I plan on......
    SWAP
    2002 6.0 with 57k miles
    4l80e trans
    DIrty DiNgO mounts 1" offset towards the back
    SLP Loudmouth exhaust (no cats)
    Computer
    Nelson wiring harness- having them make a complete harness, NOT reworking anything
    Shift kit for tranny- ANY suggestions?
    Stall converter- ANY suggestions?
    fuel pump- walbro or ac delco ep 381
    trying to find electric fans
    radiator hoses off 01-06 trucks
    throttle cable from 96 vortec and up
    fuel filter corvette 99-04- or can i use my russel -6 AN fuel filter that i already have because i did stainless steel braided lines all the way back to the tank last year
    Ill get some pics up soon
    Mar 2010
    Midland, TX
    I have some Trick electric fans for a 34" radiator I'll sell ya
    - 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
    Shopping List
    - Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
    Jun 2009
    Caledonia, MI
    This weeks accomplishments
    Whats come out of the truck so far
    Grille
    Radiator
    Parking lights
    Drive Shaft
    Exhaust halfway back (including electric cutout :-p)
    Steering shaft loosened
    Removed motor
    Right now tranny is in (being held up with tie down straps)6.0 Swap 002.jpg6.0 Swap 003.jpg6.0 Swap 001.jpg
    Nov 2010
    Durant, Ok
    I used a circle d 2800 converter and its perfect, and I still pull trailers all the time. I also used ls1 f body fans, they were easy to mount. Does your lq4 have return style fuel rails?
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by scarybowtie View Post
    It doesn't have return. How much was the t converter and where did you get it from. Goin to pull the tranny right now, possibly the gas tank while im there
    Jun 2009
    Caledonia, MI
    Got the tank out today, tranny is seperated from the transfer case. Has anyone done this swap and used the Dirty dingo motor mounts that move the engine 1" backward? I want to try and make it so I dont have to modify the rear cross member
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by HPICamaroSS View Post
    i used the adjustable dirty dingo mounts and they worked great
    Jun 2009
    Caledonia, MI
    what fuel pump to use?
    I want to stick with a Walbro....which one would be better for my application
    http://www.summitracing.com/parts/VPN-GSS341/
    OR
    http://www.summitracing.com/parts/VPN-GCA758-2/
    I was thinking its the GSS340 most are using. I used the pump from an '87 Buick Grand National on my OBS truck the first times.
    Nov 2010
    Durant, Ok
    Circle d is a site sponsor give them a call. I used the dirty ding mounts and they work great. I used the grand national pump as well
    Josh ----- 95 Z71 ecss -6.0 swap finished 10k miles ago, nelson tuned, built tranny, 2800 converter, 4.56s truetrac
    2000 z28 a4 longtubes, true duals, ported throttle body, ls6 intake, slp lid (lost in divorce lol)
    79 camaro small block street car 11.60 @ 116 (sold)
