Well, i figured since i am going to be around a while, and i like to document , i would create a build thread for this.
I have decided in the last 5 hours, lol, that i am going to put my turbo kit to use and try to break some records with my GTO before i go force inducted.
Anyways the ole truck is going to be the tow vehicle for the gto, but as some of you will find out i get BIG TIME carried away with stuff. Building is my passion, and i am SERIOUSLY addicted to it.
I will start this out with some photos along with the plans for the swap and whats in store.. Possibly i may not even end up doing the turbo kit, but we will see. all of my friends are horrible influences and telling me to do it, and im a sucker for peer pressure. I also have some major attachment to this truck and want to make it seriously nice.
Anyhow. onto the project....
This rip started out about 2 months ago when i picked it up from the farm and tried to drive it home. Shaking, pulling to the right and diving to the right on the brakes made it evident i cant even drive it home, the brake hoses were shot. So onto the tow truck.
i dont have any pictures (edit, yes i found just one!)before this unfortunately but this is after i buffed most of it and took these SUPER COOTER running boards and bug deflector it had on it off. It also had some agriculture tires that were blowing chunks of rubber off as i limped it down the road before finding out the brakes were done.
I really didnt like the 84 grill, and it was cracked from this farm hand dude that used it blasting it into something, so i swapped the front grille and core support with a 91 gmc unit i found on ebay. Well needless to say, the dude on ebay was a jerkoff and ripped me off and the grille ended up being an aftermarket pile of garbage that was already on its last leg. broken tabs, chrome peeling, the headlight bezel does not even match..
as you can see i also swapped to the 33x10.5 bfg all terrain ta's and the duramax wheels, but ive just bought another set of new tires since the ones that came with the duramax wheels were dryrotted and cashed(just wanted to use them to see if i could fit them on here without lifting it or any of that nonsense)
The new wheels i got are the rebel racing sahara 16x8's (instead of the 6.5 duramax wheels) in satin black. Same tires going on, 285 75 16 33x10.5 bfg all terrain ta, just plan on putting the white letters on the inside now.
As for the interior, the interior is immaculate. It has the burgandy with black and brushed aluminum looking interior in it. The bench seat has zero imperfections aside from a spring broken under my side so i kinda have a detroit lean like this old turd fox body mustake i used to have. The wire steering wheel thats like 18 inches in diameter got on my last nerve so i added a momo competion steering wheel and a momo hub.
The gauges are weak as hell stock IMO, and the speedo makes this absurd squeeling sound the entire time you are driving, and the stock radio is not functional, so i said to hell with it and got one of these on the way.
i dont like the sport comp series so i ordered mine with the phantom 2 backlit stepping drive full sweep electric gauges.
i will add more pictures as i upload them. Off to the garage to gather some stuff to write up in here. MORE TO COME!
