Results 1 to 10 of 13
Thread: 95 wiring removal
    95 wiring removal
    Hello, I am in the process of removing all of the now unused wiring from my original harness, 95 chevy originally 350tbi, now it's a 6.0 LQ4 with my original 4L60E trans. My question is does anyone know exactly which wires can be removed, BTW I am buying a harness from nelson as soon as I can afford it. For instance I have already removed all of the wiring that went to my original computer from the harness, which comprised most of the harness, but there were 3 plugs at that end of the harness, 2 for computer and 1 that plugs in the dash harness, will I be able to hook up to the dash harness directly or not. I have searched and found a lot but not everything I need to know yet. Any help is appreciated. Thanks
    Gramercy
    so you took all the wiring out of the engine bay?
    you didnt keep your AC/water temp/ALT wire/Oil Pressure sensors?
    thats all i kept outta my harness. im about to hook up the speedo wire as soon as i find the post by Redheartbeat then ill be ready to roll once my tune is done
    2008 GMC CCSB 6.2/6L80e swap
    Yeah I kept those, as well as the original vss wire, but it's all the other's. Especially the third plug inside the cab that I mentioned.
    Gramercy
    why did you keep the VVS, the NP harness will control the engine/tranny
    all you need is a 12v, IGN, FP, Ground with that harness other than your sensors
    Nov 2009
    Fort Smith, Arkansas
    I only removed the wires that I knew what they were. I dont know how much different yours is than mine but as far as the plugs in the dash I just unplugged the ecm, removed it, and left the plugs alone. I cut out 20 or so wires at the firewall. Looking at diagrams, i was suprised how much wiring was needed left alone. For instance, much of the wiring on the junction block on the firewall is still needed for grounds and powers for the body wiring. Also, the fuel pump relay is located next to the junction block which I used in my conversion. Im sure there are wires left that could be removed (unused wires inside the dash, for instance) but I think it would almost take removal of the dash to completely remove all unneeded wires. I recommend getting some wiring diagrams for the engine compartment, passenger compartment, and ecu and only remove what you know. Dont simply take what you need and cut everything else. If you do, you will end up with a bunch of stuff pertaining to the body harness that doesnt work.
    '91 2WD RCSB
    5.3l L59 DBW
    4L80E
    TR220 cam
    RevMax 2800rpm stall converter
    Schoenfeld LT Headers
    Nelson tuned
    My Truck Video - http://www.youtube.com/watch?v=Rw9y1...&feature=email
    Yeah, I will remove the vss wires, I don't know why I was thinking I needed them, and I believe I have most of the rest of it figured out, but we shall see.
    Oct 2003
    On my '96, I bought the GM Service Manual that had all the trucks wiring in it. Easy to understand & tells you the purpose of every wire that comes out of the firewall and the entire truck. Invaluable.
    Nov 2009
    Quote Originally Posted by LS1GMCTruck View Post
    Sounds cool. Im a real wiring dummy and I need one that gives the physical location of each wire and/or solenoid lol. Or, even better, one that says "this color wire located here is likely this" lol.
    '91 2WD RCSB
    5.3l L59 DBW
    4L80E
    TR220 cam
    Nelson tuned
    Oct 2003
    Quote Originally Posted by flattopwill View Post
    So "was" I. Never thought I would understand any of it. But, now I know(basically) how a LS1 computer functions, so I understand what to do. Yes, the book tells you where & what each wire does.
    Oct 2008
    Tennessee
    Where did you purchase the GM Service Manual and cost?
