Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: '96 Chevy 5.3L swap
  1. #11
    May 2007
    Oak Forest, Illinois
    I have never heard the term "Dirty Dingo Mount". What is that????
  2. #12
    Quote Originally Posted by Lextech View Post
    It was just brought to my attention this year as well, here you go:
    Dirty Dingo Motorsports - Dirty Dingo is your source for the aftermarket race parts and accessories you want.
  3. #13
    Great information
  4. #14
    Feb 2010
    Central Texas
    Fuel pump in a 96 would be a min. of 55 to 60 psi at least on v8 p/u but I think 4.3 was the same because of the poppet design injector system requires at least 55 to open the poppets. Doesn't the 5.3 run 60 psi
    BB
  5. #15
    Dec 2009
    Thomasville, ga
    Search my name and threads. plenty of info on the mounts.
    1984 c10-its an old truck with an LSX
  6. #16
    Oct 2003
    1996 factory fuel pump, that came in my 4.3 V-6 truck, works perfect, as is, with my 2001 Camaro SS LS1 engine.
  7. #17
    No, stock trans. It's a 60e, so we'll figure it out and get the pcm to control the trans. should work just like the newer 60e's.
    Is this possible with the stock 5.3/ls pcm's? I always thought you had to do one of the newer trannys...the 2 piece 60e's.
    If so i can get a 96 60e that was behind an lt1 for free.
    93 ECSB...lq4 6.0 swap, 255 walbro,cai, ported tb, shorty headers, 3" exhaust, tune,electric fans, NX wet kit 100 shot, 2/4 drop, beltech shocks, boss 335 22's, 295/30/22...looking for a cam.
  8. #18
    Mar 2010
    Just finished putting in a 5.3L from an '03 Suburban in my '73 Landcruiser. Got the wiring harness from Nelson Performance and probably spent about 30 minutes connecting the harness to the motor. Cycled the key twice and it fired up on the first try!
    I will get some pics and post them soon.
    I debated on trying to build my own harness or who to go with - totally glad I decided to give Nelson a call.
  9. #19
    Quote Originally Posted by DSouth View Post
    Damn Dave, welcome aboard, I didn't expect to see you on here, glad you did!
    Thanks for the feedback, glad it went on so easy!
    Send some pics over, can't wait to see it!
    allen
