Results 1 to 10 of 11
Thread: 74 k-5 5.3L swap
    Crystal Lake IL/ Houghton MI
    74 k-5 5.3L swap
    Over this past week i started my 5.3 swap into my 74 Blazer
    Freshly Painted 5.3L waiting to go into the truck
    My 74 k-5 waiting to get the engine swap done
    Front Clip Stripped off in preparation for removing the old 350
    All the extra stuff stripped off the 350
    The empty frame rail getting ready to put the new engine in
    Test Fitting the 5.3 in the frame rails
    I had to clearance the engine cross member some to let the engine drop in
    Clearence needed on the exaust manifolds
    More of the swap from this past week
    While every thing was out i primed the firewall in preparation for some paint to make the under hood look a little better
    Hydro 465 Bell housing hooked up to the 5.3
    Transmission installed onto the engine
    engine and transmission installed into the truck
    the engine mostly wired and put together
    Mostly back together now
    Is that John Deere green?
    its is supposed to be hunter green, i am not happy with it i want to go darker green
    Jun 2007
    tulsa, oklahoma
    i am doing the rust repair on my 87 K-5 now, have a 5.3 4l60 will be installing soon, hope you get it done first and then can tell me the easy way!!! good luck
    1987 jeep wrangler, 1999 LS 1, 4l60 231j transfercase, dana 30 frontend ford 8.8 rearend 3:73 gear ratio. sandersons shortie headers, 2.25 inch exhaust into 3 inch flowmaster muffler.
    sweet! it looks like you got everything moving right along. love the orange on the block.
    thanks there is no better color for a chevy motor than orange
    Quote Originally Posted by blander66 View Post
    haha damnn straight
    ac compressor fit?
    i'm gathering information for a similar swap.
    will you be using a/c? does it look like there would be frame to compressor interference on the pass side?
    Quote Originally Posted by randybill View Post
    I am not using AC thats why i have a convertable
    From the looks of it i do think that that would be the biggest area for clearence issues you sould have to do some cutting and welding to reinforce the frame
