anyone have a diagram for the pinouts on the plug? i found the wireing schematic but there are a few duplicates of wires and i dont wanna fry this thing by hooking up the wrong ones.
here is the connector
Connector Part Information
• 12110088
• 24-Way F Micro-Pack 100 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A1
TAN/WHT
331
Oil Pressure Sensor Signal
A2
WHT
121
Engine Speed Signal
A3
DK GRN/
WHT
817
Vehicle Speed Signal
A4
BRN
41
Ignition 3 Voltage
A5
GRY
1036
Class 2 Serial Data
A6
BLK
1850
Ground
A7
GRY
8
Instrument Panel Lamp Supply Voltage - 1
A8
BLK/WHT
451
Ground
A9
ORN
340
Battery Positive Voltage
A10
PNK
1020
Off/Run/Crank Voltage
A11
Not Used
A12
DK GRN/
WHT
1932
Transmission Shift Select Switch (Park) Signal
B1
LT BLU
14
Left Turn Signal Lamps Supply Voltage
B2
BRN/WHT
419
MIL Control
B3
DK BLU
507
Wait To Start Indicator Control (Diesel Only)
B4
Not Used
B5
PPL/WHT
1382
LED Dimming Signal
B6
PNK
39
Ignition 1 Voltage
B7–B9
Not Used
B10
DK BLU
15
Right Turn Signal Lamps Supply Voltage
B11
Not Used
B12
BLK/WHT
174
Low Washer Fluid Indicator Supply Voltage
wow awesome thanks!!!
tried to figure out where everything goes with the wiring schematics there are 2 that i'm unsure of though maybe someone else can shed some light
• 12110088
A1 TAN/WHT Oil Pressure Sensor Signal----Oil pressure sensor
A2 WHT Engine Speed Signal----C2 Pin 10
A3 DK GRN/WHT Vehicle Speed Signal----C2 Pin 50
A4 BRN Ignition 3 Voltage----Hot in Run
A5 GRY Class 2 Serial Data----C1 pin 58
A6 BLK Ground----ground to body
A7 GRY Instrument Panel Lamp Supply Voltage - 1---- not sure on this one
A8 BLK/WHT Ground----ground to body
A9 ORN Battery Positive Voltage----Hot at all times
A10 PNK Off/Run/Crank Voltage----Hot in Run/Start
A11 Not Used
A12 DK GRN/WHT Transmission Shift Select Switch (Park) Signal----not sure
B1 LT BLU Left Turn Signal Lamps Supply Voltage----left turn sig
B2 BRN/WHT MIL Control----C2 Pin 46
B3 DK BLU Wait To Start Indicator Control (Diesel Only)
B4 Not Used
B5 PPL/WHT LED Dimming Signal----dimmer switch
B6 PNK Ignition 1 Voltage----Hot at all times
B7–B9 Not Used
B10 DK BLU Right Turn Signal Lamps Supply Voltage----right turn sig
B11 Not Used
B12 BLK/WHT Low Washer Fluid Indicator Supply Voltage----screw it
Any body have 1 of these for an 04 year model? I have 3 green/ white I need to know where they go.
