Originally Posted by
oleshifty
I have an alpine 60x4 headunit, and pioneer speakers all the way around (except driver rear door...blew it, so i just took it out)
I have the factory tweeters hooked up.
If i turn the volume above like 25 out of 32, it like cuts off like i popped a breaker, then comes right back on a few seconds later. Only does it on harder hitting beats.
I didn't have the tweeters hooked up for a while, and never noticed it. I tried fading the front/rear speakers to see if it went away, and it doesn't seem to do it when JUST the rears are on.
Anyone else have this problem? Not sure if i need a bigger power wire for stereo, or if the tweeters or changing the ohms of the system and it's imbalanced at higher volumes.
I rarely ever have it THAT loud, but it's annoying when it cuts out and im blaring the radio (when parked in field and we're working away from truck,etc)
