Thread: tow hooks in the way
    Jun 2006
    Unhappy
    so i jst replaced my whole front of my truck from the head light housings foward and down.... i took out a light pole at 50 miles and hour. and thank good hit it dead center on my front right tow hook. talk about luck that pretty much saved my radiator back! but the telephone pole is gone. lol. anyways i was planning on installing a street scene ss bumper cover in its place. so i was wondering if the tow hooks will fit behind the cover or if they will have to be cut off or whatever involves removing a towhook. i also check and nothing frame wise is bent. god was on my side.
    05 Chevy Silverado. Regular cab, short bed.
    -4.3L
    - Sung Top tonneau bed cover.
    imco custom dual exhaust,
    custom air intake,
    ls1 build in progress..
    Nov 2005
    <div class='quotetop'>QUOTE(05chevydude &#064; Oct 16 2006, 05&#58;40 PM) [snapback]69726[/snapback]</div>
    so i jst replaced my whole front of my truck from the head light housings foward and down.... i took out a light pole at 50 miles and hour. and thank good hit it dead center on my front right tow hook. talk about luck that pretty much saved my radiator back&#33; but the telephone pole is gone. lol. anyways i was planning on installing a street scene ss bumper cover in its place. so i was wondering if the tow hooks will fit behind the cover or if they will have to be cut off or whatever involves removing a towhook. i also check and nothing frame wise is bent. god was on my side.
    i think those tow hooks are either rivited on or bolted on. I dont have a newer truck, but by the way the new silverado ss front end looks, i dont think you can have the tow hooks with the SS bumper cover...im not sure though..just my
    Project: 91' short wide:
    GMC front end update with billet grille and all clears, 17x8 & 17x11 Torq Thrust II's
    5/7 drop, almost totally shaved and 93 Deville tails
    Future Plans: 2001 LQ4 6.0L & a T-56
    DD: 98' 5 speed GT : Dumped Exhaust, CAI
    The tow hooks have two bolts. One on the side and the other on top. I don&#39;t think you could use the tow hooks with that bumper. I took my truck to a mechanic, and took them off in 5-10 minutes.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    Jun 2005
    Round Rock
    2 bolts and they gotta go
    08 HHR SS
    Jun 2005
    Cumming, GA
    Heh... And I just bought a set off ebay for &#036;5.
    2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
    May 2006
    Waco TX
    They are bolted. It will be simple.
