Well since me and my hommie Chingon have been tryin to do everything blue in our trucks ... this is what the product of our pimpness created recently :
:evil: :evil: :evil: Custom Blue Window Control LED's :evil: :evil: :evil:
So... now your thinking to your self... dizzam... how can I get some tight window controls like MacADaYear and Chingon... well first off start like this....
1)Take off window control unit
2)Take apart the unit from the housing
3)Now its time to take the switches off the unit... the best way is with a flathead screwdriver under the side of each piece...
This is what you start out with.... the tops are the fiber optic were colored blue from previous attemps at making the window controls blue but that was cleaned off before the LEDs were installed....
You can see the stock bulb with cover and fiber optic:
4)Once you get this all apart... you take the circuit out of the plastic piece and you should have this at the end of this project...
You can see where the 2 LEDs are now there in place of what used to be a bulb....
I had to route the resistor around like that so it wouldent short on anything or get in the way
Ok.. so now you have 2 LED's soldered in there with your resistor and you really think your cool now ... but NO NO NO... there is one more trick if you have the best output
5)Use some sort of reflector... in my case some insulating tape I found laying around... Ill bet some tin foil etc will work too....
The point of this being to reflect the narrow LED beam back into the fiberoptic thus creating way more light and thus making the controls way brighter and blu(er)?....
So... you started with this :
And how you have this :
Hope this helps... lemmie know if you guys like it
