Thread: stock stereo deck size?
    Nov 2005
    i have a buddy with a 2001 sonoma with the stock stereo.. i think it is the double din size right? well he wants to remove the stock radio and put a touchscreen in that area..has anyone done this to thier truck..im pretty sure that it is the same deck that is used in many of the newer fullsize trucks too. What are the measurements of that inside area? thanks
    Project: 91' short wide:
    GMC front end update with billet grille and all clears, 17x8 & 17x11 Torq Thrust II's
    5/7 drop, almost totally shaved and 93 Deville tails
    Future Plans: 2001 LQ4 6.0L & a T-56
    DD: 98' 5 speed GT : Dumped Exhaust, CAI
    Nov 2005
    ohio
    to my knowledge they are both the same double din size.
    Jul 2005
    Loganville, GA
    Ive heard that on some of the 99-02's or so without that new center console it is only 1.75 dins or somthing stupid like that and not a full 2 din because i have been looking into doing the same thing, but im not sure either, if it is a problem and it actaully is smaller just go get the dash part of an 05 tahoe or truck and i know it will def fit because thay are coming with the double din screen unit from the factory. If he doesnt want to mess with that a fold out scrrn is always an option too.
