Results 1 to 10 of 10
Thread: noises
    Jul 2005
    modesto, ca
    My truck is an 04 with only 24k miles on it, for the past 5k miles or so I've noticed a creeking sound when I have to do a realitivly fast stop. It sounds like the cab its self or cab mounts. I know its not the abs klicking noise. It can only be heard with the radio at low volume or off. Has any one else heard of this be for or any thing like it. Creeks, squeeks and rattles DRIVE ME NUTS!
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
    Could it be dry u-joints?
    Jul 2005
    modesto, ca
    I'm fairly confident that its a chassis noise.
    Nov 2005
    ohio
    when i sprayed wd -40 under neath my truck on the leaf springs it squeaked, did you use some type of lubricant on you truck suspension somewhere?
    Apr 2005
    grease your front end
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    Jul 2005
    modesto, ca
    I grease the front end every other oil change Its only been 4k miles. I guess I could give it a shot of grease again.
    May 2004
    If you think it&#39;s a cab or some other bushing on your truck, try spraying clear silicone spray on them and see if it goes away. Make sure you spray one at a time and then try to make the truck duplicate the noise.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    My Astro does that, too. I think mine has something to do with the brakes. It&#39;s like the caliper are creaking.
    Jan 2006
    San Antonio
    Ya mine does that it is the brakes like RED said. Not worried they are getting replaced with a big brake kit.
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
    Oct 2005
    Houston, Tx
    when i took my truck in for that tranny prob a lil ways back. they told me my steering shaft was rattling. so they replaced it. gotta love that waranty
