Results 1 to 5 of 5
Thread: headlight issues
    Kentucky
    headlight issues
    figured someone on here might be able to help. I've just put in projector style headlights on my 96 gmc sierra. all lights works but now my parking lights are dim not being lit fully. Only 1 is actually lighting bright like it should. I have checked all grounds and everything is ok there. Do I need to upgrade the wiring?
    Thanks
    Travis
    San Marcos Texas
    Parking lamps are not too bright to begin with. Maybe the brighter one is installed incorrectly/backward?
    Kentucky
    heres a pic. I've seen got the headlights straight but the bulbs are still the same brightness. I will check the bulbs. But the one bulb on the passenger is brighter.
    Check your grounds. You may need to add a larger ground wire from the engine to the body or frame.
    Kentucky
    well guys i appreciate the help. I got into checking out the wiring today and it has been patched in the past. So the next day I have off I'm going to look into rewiring most of it. I'll post pics later on.
    Thanks again.
