Do you guys like this wheel? On a white truck of course.
Gone, but not forgotten!
Is that like a chrome silver color, or is it similar to the JG wheel you have? They look pretty tight though.. see if they have them in black. Your truck would look so tough with black wheels
that thing looks heavy... Not that it matters on a truck anyhow. Not bad looking i guess.
i like it. if u decide to depart with ur JG wheels let me know!
i like the ones you have on it now. but they aren't that bad.
I like them. What is the weight on them? Mine weigh as much as a cow, and My mickey Thompson wheels only weigh 29lbs(16X12 8 LUG), that I have my slicks mounted on.
I am looking for some light 20" wheels in Black.
Jamest
12 Sec. Club! SOLD
SOLD***
my mom has those on her tahoe but 20 and chrome they r heavyer then my 22 om my thruck i like your jg better
