Results 1 to 5 of 5
Thread: xenon headlights
    Apr 2007
    mansfield,texas
    I recently installed pair of 8000k xenon h.i.d head lights on my truck and they flicker ever so slightly... Is that normal with xenon ligths? Do they just need to break in more?
    Mar 2007
    I have installed those on 6K on Low beams, Hi Beams and DRL, and what I have to do to cure that problem was install a 30AMp relay to boost the signal that came from the original socket, it was to damn weak!!!!
    One realay for each set of lights.
    With the Relay install, they turn on Quikly and dont heasitate for anything, and btw, I Sum L/H beams when in high, is hell of white bluish on open road!!!!!
    Apr 2007
    mansfield,texas
    I have a special wire harness that came with them it has a relay and a inline fuse the wire harness is connected right to the battery so I dont think that would be the problem would it?
    Mar 2007
    Nope, there is were it supost to be conected.
    the low beam came with the harness u describe, but the High and DRL did not. They come on, but not as fast and steady as they do now.
    Sorry mate, that's my only Xperience with the Xenon.
    Apr 2007
    mansfield,texas
    Ok, I figured out my promblem.... only problem is, is that i returned my kit blaming the flickering on the kit... i need to install capicitors to each of the wires running to ballasts because the lights are sensitive to my alternator....now if someone would recommend where to buy a good kit with a harness for 300 or under i would like to kno...
