Thread: door panels
    Apr 2007
    friendswood
    Im in the process of changing my front door speakers, and I thought I would be slick and just pull the grill off, and now when I put it back in its not in there tight. When I pull the panel off can i just bend the clips back or do I need to get a replacement?
    2006 ecsb silverado, AFE Cai, Jet Maf, Pacesetter Ceramic Coated Lt's, true duals with Dynomax Bullets, cats and o2's....still emissions legal!
    "Ford...At least they circled the problem".
    Uh...pulling the grille off was not the way to go...I would try doing exactly like you said...Take off the panel and try to bend the clips so the grille is nice and tight on the panel...and there isn't a thing on this Earth that a little duct tape won't fix....hehehe Southern Engineering at its greatest!
    Jul 2005
    Loganville, GA
    i made the same mistake once out of bordom, if you take the panel off the door just pull the speaker grill back in tight and bend the tab back over like it come from the factory and you should be golden
    Apr 2007
    friendswood
    thanks guys. a guy at my audio shop said he could just mold the new ones into the door, I dont know too much money for me.
